anything wrong with regular pvc
does 150's all day long. i attached the ports with liquid nails
is there anything wrong with using regular pvc pipe, for an aeroport, instead of the flared kind.....will it cause a lot of port noise or something.....btw, how would i go about attaching the ports to the box?
I had been wondering the same thing. I think PVC would have alot of port noise as the flares are there to lessen that. As for mounting them you just cut a hole the same size as the PVC, slide it in, brace it internally. Preferably glass it into the box.
You can also make flare ends out of mdf with a 3/4 or 1" roundover. It's not as much flare as the precision ports, but better than none and easy to make.
I was thinking thatd be possible. However PVC is highly toxic if actually burned if i recall correctly. Did you flare your ports? Id prefer to use PVC in my ported box builds if i can, whats the cost of it now? I need some 3" pvc for the next box build.
thats why you dont burn it lol. but just get it nice and hot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
oh and you can flare your ports with a heat gun and a glass bowl to make the flare
exactly what i did with my 4 6" aeros.. worked good. takes time to heat up the pvc enough to get it to flare nice and even without burning it though. got to be patient
if you just sand the edges smooth, and have close to the recommended port area, you'll have no problem. Using 4" thin wall pvc and elbows makes using round ports a lot cheaper. I used liquid nails to attach mine in my new box, works great.
302yota
302yota
rockingham, NC
netzero
AJ (ACE)
    Jun 28, 2026
