Anyone got a problem with Scosche wirring?
i've used many of the kits from wally world and never had a problem. i'd never use the kit with the cap but the rest are fine. may be somewhat smaller than others; but the average person shopping for wire there isn't running 2000 watts anyways.
if you do intend on using scocshe go bigger than you need to get what your going for.
as in you need 4ga, better get 1/0 scocshe
If you recall KnuKonceptz is CCA (Copper Clad Aluminum) so they make it thicker then normal because it has to be in order to handle the same amps as pure copper wire
BZZZT. Wrong.
Only Knu's KLMX wire is CCA.
Kolossus is pure copper, and Flex is Tinned copper (Resists corrosion)
good to know. guess that means it's not the best then. i'd prefer pure copper over CCA personally. thats kinda like cheating LOL
If you understood why the product was designed you would realize its a good thing.....
Here is a photo of my E2, Kolossus, and Monster 1/0 for comparison purposes:
The photo follows that order too: e2 on left with red techflex, Kolossus (blue) in the middle, Monster (clear/white/whatever) on the right.
if its CCA stay away tinned copper is good for corrosion resistance and still going to be small like OFC but OFC has no protection like the tinned stuff and can corrode. I have welding cable that is OFC (thanks former work) But i protected the ends with liquid tape and dielectric grease hoping it helps. CCA looks bigger but the AL expands and contracts coming loose in set screw connections over time. AL is no longer allowed by code in may areas for electrical work. sorry typing while drying little dog.
= spankin' the monkey?
letchcore
letchcore
Nashville
WhoSayWho?
