Take a DVC driver, run T/S parameters on a single coil with the other coil open. Make notes.
Run the numbers again on a single coil but with a resistor between the terminals of the unused coil. Make notes.
Run the numbers again on a single coil but with a higher value resistor between the terminals of the unused coil. Make notes.
Run the numbers again on a single coil and short the other coil. Make notes.
Compare notes. Among other things, notice how driver Q changes?
With the unused coil being shorted you have higher braking force (higher electrical damping) than with the coil open. Lower BL, lower thermal limits, lower sensitivity, etc...
