Any way to manipulate the overal impedance(ohms)?
bromo thanks a lot for that. Please tell me if I interpret the data correctly:
Looks like you're using a D4 sub? About 3 ohms DC per coil, 4 ohm nominal?
With one coil open the impedance range is 3.077 - 14.28 ohms, and with the coil shorted the impedance range is 3.077 - 5.361 ohms? Do I read that correctly?
What frequency range is that measured over?
I was intending to do an experiment myself this weekend, but my test equipment isn't quite as sophisticated as yours. And it's damm cold in my workshop...
Thanks again.
Yes it is a D4 ohm sub, LA Storm Neo D4 to be exact.
1hz to 20khz
Thanks again.
lol, just a WT3 from PE.
1hz to 20khz
Thank you bromo, I did about the same thing last night, first time using arta limp. I found the same results- but I had problems with only running one coil. I kept getting "bad data error" when trying to calculate TsP. I think it is my jig, but it doesn't matter. The graphs looked the same as yours.
For any one that wants to hook a dvc sub up with just one coil. Play full range pink noise at a low level. Then short the other coil. It has a big difference on the sound and spl.
If anyone is intrested I can get the fr of a sub hooked up like bromo did for impedance.
ATN2DETAILING
ATN2DETAILING
BURBANK
duanebro
