It has no effect. It's easily proven. You can't tap on a woofer and know the difference. That was silly to even say. Nobody can take you seriously now guy."Qes The driver's Q at resonance (Fs), due to electrical losses; dimensionless. "A measurement of the control coming from the speaker's electrical suspension system (the voice coil and magnet). Opposing forces from the mechanical and electrical suspensions act to absorb shock.""
Now since the coil has nothing put into it, it can't actively oppose the fixed magnet in the motor. A coil in a magnetic gap does indeed generate a voltage. That voltage will have the same polarity as the magnet. So, shorting the coil would actually cause the coil to at all times be attracted to the fixed magnet which would hinder the performance of the woofer.... but that voltage is so tiny it would not at all matter. If it weren't tiny, since it is dc current, it would blow the coil. This is all simple and basic physics as well as electronics. You guys have to start using your heads.
