Any real difference in using Gold vs Silver ring terminals?
The purpose of gold plated terminals isn't the conductive properties of gold (which are good, but only marginally better than copper...or even aluminum) but the NON REACTIVE properties of gold. Gold plated terminals will never corrode, oxidize, or tarnish.
I had based it off of the Audio Savings description saying it was Hyper Oxygen Free Copper.Audio Savings | Cadence 0G100-BLACK 0 Gauge 17 Feet Car Amp Power Wire Cool Cable Technology
Model: 0G100
Gauge: 0 Gauge
Wire Length: 17ft
Cadence Cool Cable Technology
Special Winding Configuration Reduces Unwanted Noises and Maximizes Current Transfer
High Purity Oxygen Free Copper Standing
Incredibly Flexible Yet Extremely Durable
Protective Ultra Soft PVC Translucent Jacket
Braided Super-Flex Design Ensures Optimum Surface Area and Flexibility
Designed for Show Car Performance
1 Foot Markings on Wire Make it Easy to Read and Easy to Cut to Appropriate Size
Ultra-Pure Copper Conduction
High Current Competition Class Power Cable
Eliminates Noise from the AC Line
Shielding From RFI and EMI
Resist Abrasions, Chemicals, and Temperature Extremes
Rated at 110°C (Celsius) / 230°F (Fahrenheit)
Guaranteed to Make Your Amplifier Run Cooler and Sound Better
Stranding: 7 x 7 x 55 x 0.15mm (7 Ropes Consisting of 7 Sets of 55 Strands of 0.15mm Wire)
Color: Black
Also Available in Red / Blue
that is the description, where did you read the words "hyper oxygen free copper" or even the words "oxygen free copper" or "OFC"? exactly
6 lines downHigh Purity Oxygen Free Copper Standing unless thats not what I think it is.
the words purity and stranding, really? explain to me how you figure that Cadence can sell OFC wire cheaper than every single company that sells OFC wire? especially since it's more than half the price difference. serious ppl need to use a little more common sense and get better educated on simple things.
And I have been slightly educated. :V
just keep in mind that Cadence wire is actually very good wire. it's actually one of the better CCA wires on the market especially for the price. I use a lot of Install Bay wire which gets completely malled on the forums but I know its CCA wire and what kind of power it can handle.
Well what I was planning on running was a Skar SK1500.1 @1ohm so just under 1400watts, thats probably too much for Cadence wire then right? Would it be okay with that wattage/use in the car for power/ground?
what other amps are you going to be running? what size alternator? how long of a run?
Just the Sk1500.1 for now, in the future getting a second SK1500.1, then after maybe investing in a SK80.4 (but by that time I'll upgrade further).
105a alt (ran perfect on my Alpine MRX-M100 @1000watts)
And from Front to Trunk, the Kicker 4gauge kit I use now is 20feet which is plently long. So between 20-23feet.
VisceralSound
VisceralSound
Rochester, MN
VisceralSound
