Any real difference in using Gold vs Silver ring terminals?
Just the Sk1500.1 for now, in the future getting a second SK1500.1, then after maybe investing in a SK80.4 (but by that time I'll upgrade further).
105a alt (ran perfect on my Alpine MRX-M100 @1000watts)
And from Front to Trunk, the Kicker 4gauge kit I use now is 20feet which is plently long. So between 20-23feet.
since you are already planning an upgrade, i'd just get either kicker hyperflex 0 gauge or knu fleks 0 gauge. the cadence wire could hold one 1500 and 80.4 but not a second, you'd definitely need to make a second run with the cadence (not a bad idea for a second run no matter what wire you get). if you do get the second 1500 you'll either need a good AGM battery up front with a second in the rear or a good AGM battery in the front with a moderate increase in alternator size (maybe 200-250a). either one of those routes will need a 0 gauge big 3 (that should already be in the plans if not already done in 0 gauge). me, personally, i'd just get the 80.4 with a cadence or kicker 0 gauge dual amp kit w/big 3 upgrade and complete the system.
That's wiring the single 1500.1 and 80.4 together right? using a distroblock or something for the 4 channel?
VisceralSound
VisceralSound
Rochester, MN
VisceralSound
