OP
KyleBechtold
Quit reading this
- Thread Starter
- #16
what? the batts are 12v batts.. the charging system is 14..... R u running a 14v setup or 12v?
what? Every car I have ever heard of has a 12v battery and you charge at 14 from the alt?? atleast in the USAUm that mite be a prob...
Lulz I just told him that on the phone.what? Every car I have ever heard of has a 12v battery and you charge at 14 from the alt?? atleast in the USA
I am good with the audio the electrical is whats got me going.. I have a hc 2400 and a 1400 with a stocker up front.. Well.. when driving along its fine voltage is good I can be wanging on 2400-3200+ watts voltage might dip to 13.9. usually won't unless ac is going and what not.. well at idle with no music going or REALLY low I will sit around 12.9-13.2... if i put it in neutral it goes up a little or park.. now if I rev it a little It will go 14.. This has me thinking the alternator is shit for Idle but thats like 0.. my car sits at 12.9-13.2 when off... I will get the alternator tested and go from there but If i remember correctly my last alternator.. a stocker did the same.. the alt I have now is a 200a Db electric.. stock pulley size so that may be part of it..
Also at idle the car will kinda shake when the voltage dips down and will shake until I go or put it in neutral.. the rpms go up a little when doing that.. So idk if its the car idling to low or the alt being a piece at idle or what.. also when I put up my windows it dims my lights and drops my voltage .2 or so while doing it.. like wtf? they shouldn't be that much power
wait.. what? unplug the harness when its running? and then take the voltage? that won't possibly fuck something up will it?I didnt read any posts beyond this, but if it hasnt been mentioned yet. Unplug the alternator harness and check voltage that way. Your vehicle may beep at you if its a newer vehicle, but this will give you a good idea if it is the regulator on the alternator or if its something else on your vehicle
the alt doesn't charge at 14 unless i am over 1-2krpm.. otherwise I am resting on my batts at idleYour alt charges and 14v and your batteries sit at 13.2v.
Theres nothing wrong.
