any ideas? *pics*
fakename
wellllll i finally got around to taking off the cover to my broken amp. anything look irregular? i found a piece of solder rolling around.
Doesn't look like anything went *poof* if that's what you're asking. Certainly doesn't mean that a component isn't bad. The controller ICs could easily go bad without any outward signs, same with any of the diodes or transistors. It's not really uncommon to find an extra blob of solder. It coming loose from whereever is was stuck and rolling around might have shorted one of the ICs. Easiest to let a professional tech deal with it.
The flux regulator that connects to the sprool lever over on the right......kinda next to the shinsome board looks like it arched against the regulator.......//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
****!!! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif .........I dont know //content.invisioncic.com/y282845/emoticons/bawling.gif.6287aa5d1d447c8af063fc9466e822ef.gif
Don't forget about the kneutson valve
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what kind of amp is that? those internals look really weak, im guessing audiobahn. but yea it doesnt look like anything burnt up
lanzar //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
fakename
fakename
earth
Loudrango112
