Any comments on my first system?
mattf
Veteran of CarAudio.com
Just wanted to say hey and this is my first post here, but I've been reading for a while now.
I just got my first system last week. Its got -
Pioneer DEH 3700MP
2 - 12" Kicker Comps
Power Acoustik 620w amp
I built the box myself, its a sealed box with 1.6ft^3 per sub. I haven't got it carpeted yet. Where would I go to find carpet for it? I've never seen stuff like that in a store before.
For the amp settings, I have the level set at about 60% up, the cross over on low pass, and the lpf setting on 40hz.
I'm not really sure what all of these do exactly, so I hope they are set alright.
The sub wiring is also another area of confusion for me. Right now I have each sub wired to the amp separetly, sub+ to amp+ and sub- to amp-, for each sub. Does that sound right?
I would really appreciate any comments on the setup/settings if you got em. I know you guys like pics, so I was sure to get some, even though I haven't quite figured out the Photobucket resizing thing yet. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Matt
It is a great first system. And to know you installed it yourself, congrats!
My first system was a bit extreme, a pioneer supertuner I, Jensen 250w 11band graphic eq, 4 pairs of jensen quadrax 6x9's in the hatch of my '80 mercury capri. thing would kill your ears with treble and midbass was decent, if you didn't distort them very much. So to look at your first system, well done!
Congrats and welcome......
You'll soon enough realize a 'system' consists more than just a HU, subs and an amp. I would've liked to see you start with a fronstage and then find subs to integrate, but heck most people do it the way you did. You get props from me because you built your own enclosure, good to see....
Eight footballs in the hatch? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
DId you seal the hole where the wires go into the box w/ caulk?
Get some terminal cups by the way... it just looks so much better!
Terminal cups are 'teh ghey' //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I like to run straight wire from my amps to subs myself. The less connections and wire taps the better.
Yep.
Yeah, I know, I just used that for a lack of better words. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Thanks for the comments, and I'll look into the carpet.
Matt
First off what is the coil configuration on your subs?..... Also I usually get carpet at Wal-Mart. It's back in the automotive section usually under the floor mats. Use that with some good spray adhesiv and stples on the bottom. A roll is like 9 bucks after tax and you'll need one or two.
First time do-it-yourself-er... extremely well-done. You'll probably just need a little Neosporin and a band-aid for that bite "the bug" just gave you *hehe*. Now you're in it and there's no turning back, buddy.
Curious, did you get enclosure volume advice from someone, or from the owner's manual, or just a good guess?
Yea, swing by Pep Boys, Auto Zone, Checker, or pretty much any main-stream auto accessories/parts store and you'll find "trunk liner" carpet (near some other fuzzier stuff) that will match your trunk perfectly. You may even want to use it to re-do your existing floor panel to clean it up.
Since you already have the speaker cable holes drilled, you may be interested in a set of binding posts. Although straight cable provides the most lossless bridge into the box, some of these puppies work quite well and look good: http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3
mattf
mattf
OnYrMrk
