Anti-theft System
re-wire your alarm to run on a "back-up" battery. it will help in ways if your alarm were to ever go off and thieves cut the battery in hopes of shutting it off will allow the alarm to continue. also if you have to d/c your main battery just isolate the backup so the alarm stays active while your main is disconnected allowing you to do any work you need to. then when you hook it back up like normal there should be no reset alarm or anything.
Ty. Sounds like a good idea.
Need to find the wiring diagram for this year car. Then I can work on a backup battery system for it.
ST33M
Not Loud
ST33M
Wichita
ST33M
Mike Mccabe
