Another stupid component question from a newbie
bdog4fosgate
I was just wondering if component speakers were like coxials only better or are they just bass pushers like subs? I don't want to buy component speakers if they aren' regular type speakers........I already have subs and I want speakers now. Please help.
Components are "regular" speakers except the woofer and tweeter are actually separate speakers, not built into the same frame. You get more control over the sound quality because the crossover is also a separate item. They usually take more power than equivalent coaxials too.
Thank you, here is another one for you then while we are on this. I have a Jeep Grand Cherokee with side panel speakers for both front and rear, would you reccomend components for both front and rear or just the front?
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
603
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
885
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
bdog4fosgate
bdog4fosgate
Indiana
McCraperson
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
