another rim question.
  • 4
JL Audio
ThugStep
13,839
KY
can anyone tell me what rims these are? i've looked online to try and get center caps but not having much luck as the guy selling doesn't have the center caps for any of them and he got them from someone else.
Here are the pics of them as they are:
No markings anywhere on the backside?
there was some small numbers on each of them when I got under to check.
Is there a way to use those for searching? No logos or anything anywhere though.
Judging by the sunny tires he has on them I would be pretty confident that they are just a cheap ebay wheel, probably wont even be able to find center caps.
On a side not, how cheap is he selling you the wheels and tires? You have to get adapters to make them work so wouldn't you be better off putting that money into your rim fund and waiting till a set of wheels comes across cl that fit your trailblazer? Just my .02 not my money being spent so...
400 for rims with tires together. Already have the adapters now.
Those look to small for a trailblazer. Measure your stock tire across and then measure the ones you are looking at. They should be within a 1/8 inch of each other assuming tire wear is about the same.
Will do.
Sidenote, I did figure out they are DARE alloys CODE:DW445. I can't find anyone whom carries them sadly and the site is listed over in japan or something, they have no american contact email or dealers that i've seen via google. I am thinking to just plastidip the whole thing or somehow get them flat black and not worry about the centercaps.
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
JL Audio
ThugStep
JL Audio
KY
JL Audio
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
