im trying to set the gain on a sundown 3000D amp. i bought the DMM yesterday from HD. pulled the speaker wire from the amp and connected the DMM. set my HU EQ to flat, turned loudness to the "off" position and raised the SW level on the HU as high as it would go.
this amp has bass boost along with a remote bass knob. i turned the bass knob all the way down and turned the bass boost level on the amp all the way down. put in a test tone, 32hz at 0db. (I choose 32hz because thats what my box is tuned too. thought i read thats what you were supposed to do somewhere, but i think i should have choosen somehting a bit higher?).
my HU volume goes to 62. the highest ill ever turn it up is right around 45, so i turned it up to 42 and played the tone.
now, when the gain was all the way down, i was getting a 0 voltage reading. i turned the gain all the way up and the highest reading i got off the DMM was like 4v. so now i started playing with the SSF, LPF, phase, and bass boost on the amp as well as the remote bass knob (all of which i set as low as they would go at first). after messing around with these and the gain, i got the DMM to read 49v (using the formula, i came up with a setting of 50v. sqrt(2500w*1ohm)).
does it seem like i did everything correct? i thought when setting the gain, the SSF, LPF, phase and bass boost(as well as the remote bass knob) should all be set as low as they can go. thing is, when they are all set as low as they go, the DMM only reads as high as 4v?
do you think i should try setting it again using a different tone? which tone would you guys suggest?
