Another amp?
  • 2
n_derr
I'm buying a pair of Infinity Reference 9603i and a pair of Infinity Reference 3002cf for my car and I was wondering if I'd notice any real difference in sound quality if I installed another amp for these. The HU I have is a JVC KD-LH3100, and it gives 19watts RMS/channel (50watts peak).
If you think an amp would improve sq, what amps would you recomend? Limited budget, though.
Thanks in advance
Yes your system will sound better with an external amp. Those speakers need atleast 60rms watts each. What is your budget on the amp. I would suggest a 4 channel amp. US Acoustics are pretty cheap you could get them at sounddomain.com or crutchfield.com
I'm looking at amps in the sub-$200 range. From what I've seen at sounddomain.com, I can get some pretty decent amps for the wattage I'm looking for. I just wasn't sure if there'd be a sound quality difference.
I was also thinking of buying new speaker wire. Since I'm going to be gutting the car to put in subs and an amp, I figured I'd replace the wires, too. What would be a good gauge to run to these speakers?
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
876
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Haven't 100% landed on which one, but I am down to those two
12
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
534
They managed to turn Covid into a wedge issue.
n_derr
n_derr
Watertown, WI
n_derr
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
