Another Alpine Type R Thread
If you absolutely want a 2ohm final load then get the DVC 2ohm ones and wire them either in series then parallel'd together or vice versa. I would advise you to get a 1ohm stable amp and get the DVC 4ohm ones though because to an amp that would adequately push two type R's at 2ohms would prob be fairly costly whereas an amp that puts out the power at 1 ohm would be more than likely cheaper. This is of course if you don't have the amp already. Let us know if you need amp suggestions.
well ya if your amp can go to 1 ohm if not or if you dont feel like running 1 ohm then 2 ohm dvc is what you need
2 ohm dvc can be wired 2 ohms or 8 ohms or .5 ohms
4 ohm dvc can be wired 1 or 4
Chimps
Chimps
LA, California
SicAudio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
