Amps
  • Thread starter Unregistered
  • Start date
  • Replies 7
  • Views 931
  • 3
U
Unregistered
Guest
What up everyone
I have an SQ-Series 15", 400watt, 4ohm Hifonics subwoofer - SQ-154. I was wondering what would be the best amp to use to power this sub?
thanks
I have 1 sub. Just give me an idea of the best amp I can get to power this sub for the lowest price. Also, does anyone know where I can find single 15" bandpass boxes online or know of a catalog I can order or something?
thanks
this post is for zane
thanks for the advice, but i do have a couple questions. I dont know much about amps so i was wondering if that amp you suggested will really be enough power for that sub? like, whats the difference between 4ohms stereo & 4ohms bridged? I mean I have no idea so do u think u could kinda explain like what i should look for in an amp to power that 15" 400watt hifonics sub?
thanks alot
The amp I reccomended will power your 15- and likely then some. PG amplifiers have always exceeded thier specified power ratings and hold up quite well.
In concern to the Ohms bit....
4 ohms stereo would mean that the amplifier is using 2 channels each channel to power a 4ohm speaker.
4 ohms mono would men that the amplifier is using its 2 channels combined into 1 mono channel powering a 4 ohm speaker.
Since the amplifier is more powerful running mono, it would offer an advantage over a stereo output. It does this by summing the power of each separate channel into 1 more powerfull channel.
There can be advantages in using a stereo signal too. Some amplifiers are 2 ohm stereo stable and not 2 ohm mono stable. In this case, a stereo configuration would obviously be the better choice.
take a look at these links for further explanation:
http://www.eatel.net/~amptech/elecdisc/ohm.htm
http://www.eatel.net/~amptech/elecdisc/ohmslaw.htm
http://www.eatel.net/~amptech/elecdisc/srsparll.htm
take it easy,
-zane
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
155
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Guest
zane
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
