Amps
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 616
  • 1
U
Unregistered
Guest
Hey! I've got 2 440 clarion amps(4 ch.), ones bridged to 2 10" subs and the other runs to my speakers. Can anyone tell me what gain, filter, and bass extender mean (on my amps) - im playing around with the sounds. Also, if anyone knows the best hz, fz, or db that each should be. Thanks
think of gain as a volume control
my hu puts out 4 volts, and idealy i'd have the gain at 4 volts to get max SQ, but I need more power than that so i turn it up. Way to do this if 1st internals, turn off or unplug subs, turn deck to a HIGH level, and crank up gain till speakers are screaming.
Filter keeps certain frequencies from getting to your speakers. High pass internals, and low pass subs.
Bass extender sounds like bass boost
best freq and db depends all on your ****, play around with it
have fun :p
4 channel amps really are not that great at powering subs. They are more for components so you dont have to buy several amps just 1 4 channel or 2 depending on how many components. Go with 2 (2) channel amps and bridge those maybe try a couple of MTX Thunders use the 4channel amp on your components. IMO then adjust your gains from there
431
561
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Guest
