amps
  • Thread starter s104inchbodydropped
  • Start date
  • Replies 3
  • Views 1K
  • 2
S
s104inchbodydropped
Guest
I want some opinions on some good amps im am pretty active in the car audio area myself but i want some public opinions. I have about $400 to spend on an amp im going to be wiring it to prolly 2 10's or 2 12's and i want to know what amp yall think will be the best for it.. I have been thinking alot about the Rocksfords amp but I have been hearing JL has a bad ass line of amps out right now so i want to know which amp yall think i should run with. Also the truck is a regular cab if that helps any.. and if anyone knows how to make custom boxes to fir 2 10's or 2 12's in the regular cab s10 give me a holla and i will prolly ook u up with some work.
im trying to stay whith a whole matching system like if i go JL amp i want jl subs like that whats a good setup to have
152
413
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Guest
    May 16, 2024
    May 16, 2024
