Amps for SQ
http://www.carsound.com/review_archive/amps/jl_5001.html
According to carsound it output virtually identical power into both impedances. But technically, it did output more power into 2ohms. Not a difference worth mentioning...but more none-the-less
dont ever quote magazines. ever notice that they hardly ever have anything good to say about a company that doesnt have a full page advertisment in their magazine?
I do know that the JL 1000/1 will work well. I have run it on 4 10W6AE's, 2 15W0's, 2 Focal Access 40A's and it's worked like a champ and made incredible sound. I even had people ask if I had ported 12's when my 4 10's hit. It was pretty incredible.
Unless you can prove any imperical evidence to the contrary, I see no reason why it can't be quoted.
So, lets see those test results from someone well respected within the industry, using proper testing equipment and procedures...such as the above test report I linked.
What's that? You don't have one?
JL Audio 500/1 Specs
Price & Contact: Call for pricing; Tel: 954-443-1100, Web:
www.jlaudio.comAll measurements @ 14 volts unless otherwise specified.
Frequency Response (4-ohm IHF Load, 60 Hz Ref., crossover disabled): +.0dB, -3 dB @ 530 Hz
L/R channel error max deviation 20 Hz to 20 kHz: N/A
Signal-to-Noise Ratio (Below Rated Output, “A” weighted): -108.4 dB
Distortion at Rated Output @ 60 Hz: 0.17% THD+N @ 500 watts into 2 ohms
Output Power (Resistive) (4 ohms @ 60 Hz to 1% THD+N): 605 watts @ 14 volts; 601 watts @ 12.8 volts; 591 watts @ 10.5 volts
Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 620 watts @ 14 volts; 604 watts @ 12.8 volts; 598 watts @ 10.5 volts
Output Power (Reactive) (4-ohm IHF Load @ 60 Hz to 1% THD+N): 639 watts
Output Power (Reactive) (2-ohm IHF Load @ 60 Hz to 1% THD+N): 733 watts
Crosstalk @rated output, 20 Hz to 20 kHz: N/A
Damping Factor, 2 ohms @ 50 Hz: 225
Voltage for Rated Output: 72mV to 8.3 volts
Idle Current Draw: 1 amp
Current Draw @ 1/3 Maximum Power: 26 amps @ 206.3 watts
Efficiency @ 1/3 Maximum Power: 57%
Power-Up Noise: 19.9 dB SPL
Power-Down Noise: 37.2 dB SPL
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif btw Mansville Smith of JL Audio is a member of CS and I wager to say he'd say the same things;)
coming from a guy that tossed both of his 500/1's to the side, i can tell you that after a few minutes of running those amps hard at 2 ohms, that the power is decreased. they will never shut off because they reduce the power to avoid it. end of story. i guess all of you have had the time to really test them, so you would probably know best. a simple quick bench test wont tell you the full story. you need to really test them with all variables to get honest results. sorry JL fooled you all.
So what you are saying is that you drove the amplifier to the point that the protection circuitry kicked on. I hardly see how that proves anything other than you abused the amplifier, then got upset because instead of shutting off due to thermal protection (like other amps) the JL amplifier rolled back the power. So, it functioned exactly how it was supposed to, and this makes you unhappy for some unknown reason. Yeah, makes total sense to me now... //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
You stated that the amplifier output less power into a 2ohm load. We provided evidence to the contrary, thus proving you wrong. It is fully capable of delivering the same amount of power into a 2ohm load that it does into a 4ohm load.
Sorry that you don't know how to use your equipment.
no its not. and you cant prove it either, and i cant prove jls better so. lets just not make comments like that anymore ok? thanks again.
so you are saying the slashes are on par with the c2k's? //content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
1. So what you are saying is that you drove the amplifier to the point that the protection circuitry kicked on. I hardly see how that proves anything other than you abused the amplifier, then got upset because instead of shutting off due to thermal protection (like other amps) the JL amplifier rolled back the power. So, it functioned exactly how it was supposed to, and this makes you unhappy for some unknown reason. Yeah, makes total sense to me now... //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
2. You stated that the amplifier output less power into a 2ohm load. We provided evidence to the contrary, thus proving you wrong. It is fully capable of delivering the same amount of power into a 2ohm load that it does into a 4ohm load.
1. yes, that is what it did because it makes more heat at 2 ohms which causes the amp to heat up much faster than it does at 4 ohms, resulting in the amplifier reducing its output to avoid shutting off because after all, JL says it will operate at that ohm. i never said it drastically cuts back, but consistantly it will put out more at 4 ohms, where periodically it will put out more at 2 ohms, but that is kind of like you in bed. those two seconds are great huh?
2. you repeated yourself again. and yet my reply is the same.
dyabolical
dyabolical
Tulsa, OK
Towncar
