Amplifier Help
[quote name='>>SQL
Ditch the 3 sealed 10's' date=' go with 2 - 15's ported, build a sofa / bench over the box for more seating.[/quote']
Or, just have one bench in the second row and build a clamshell/wall in the back, since the doors don't open anyway? //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I was thinking on the clamshells doors. Also my dad agreed and we will sell the 3 10's setup and get a 2 box. Now i have a whole new set of questions like 2 box better than 4 box and 2 18's or 2 15's considering the same price range.
4 15"s or 18"s would SLAM. But your whole budget will change as well as how much power you want to run. If you where looking at 4000wrms and 2 fi btl 15"s or 18"s you will slam that van apart and be happy. Also the SSA xcon or zcon. Sundown zv2 or zv3 would do perfect //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif the zv4 would be ideal but those are still alil while before production. Nightshade v1 or v2 work. AUdioque is well priced aq hdc3's could work. DC lvl 4xl or lvl 5 as well altho i used a xl recone on a omega and wasnt impressed with the lows. I could go into 4" drivers but that again goes back to power. give a price range can go from there would love to see a mean van build //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif let me know how much power and driver budget and what your goal is audio wise. GL on your endeavor bro.
We have a second regular car battery in the back soley for audio and compressors charged by the alternator. Also, i have 700 in the bank and might put all my christmas money on that so around 1700.I think i would get 18's over 15's just because of size and they look better. Is it better to but brand new or should i trust people on this site used subs?
Generally this site is reliable with classifieds. For new subs id recomend two DC XL 15s, they are around 470 a piece shipped to our area. Then grab a nice 3.5k like the crescendo. That will leave lots of budget leftover for a box that can look as good as that one you have now..
if you are new into car audio, do some research on power requirements before you spend thousands on equipment.
A $5,000 system will sound like **** if all you have is a stock battery and stock alternator with 4 guage wiring.
You might be better off starting with a 1000 watt system and then building up from there.
So you are saying I should get a 2 15's or 18's box that would go well with higher end subs and get ok subs and amps now and upgrade as I get more money and more into it?
One of the car audio concepts that I got wrong when I first started learning was assuming that your car battery and alternator puts out unlimited power. This is not like plugging a 3000W amp into your house and it draws 3000Watts. In a car, you are limited to the voltage of your battery and how quickly your alternator can recharge that voltage. As the amplifier draws power from your battery, the battery's voltage drops and therefore the amplifier produces less power. Your alternator charges the battery. If you are draining power faster than you can recharge it, you aren't going to get rated power from your amplifier or your subwoofers, and so that $400 sub and that $1000 amplifier will perform like a $100 sub and a $300 amplifier. Some amplifiers are made to put out rated power at 16V, some at 14, some at 12V. If you buy an amplifier rated at 2000W at 14V, you may get that 2000W during the first few minutes of play, but as the battery's voltage drops you are going to be getting less and less power. Unless you have enough batteries, or an alternator capable of recharging at the rate you plan on discharging, you aren't going to be getting what you paid for plain and simple. It took me a long time to actually learn this, so I'm just spewing some knowledge.
Don't buy a pre-fab box. Either do some research and build your own (like I did) or pay someone on here or locally to build you a good box. I would say a majority of the sound you get out of a subwoofer will be based on the size of the box, its tuning, size, and placement.
Sundown is bringing the z.4 into production and their 10" model is supposed to be rated at 1750 rms if i'm not mistaken.
Here is the link to their prototype video -
Three of those would beat up your van pretty **** good as long as you've got the power to back em up.
My last post needed to be checked my a moderator because it had a hyperlink so no more hyperlinks.
Lots has happened since my last post, my dad met a guy that works at a electronics warehouse that can get all alpine brand 40% off so now my setup will be alpine.
Looking at alpines the only logical choice that would shake my van would be type x. Now we are thinking 4 type x with 2 amps or however many amps. Is it better to run 2 or 1 amp and what alpine amp setup eould be good?
Finally is a sound processor worth it? Alpine makes this thing that apparently makes sound quality better like it adjusts music based on your car. Look it up or tell me if it seems legit or what your opinions on it are.
poweras1
poweras1
Rochester, NY
poweras1
