Amp wont power up:(Very WEIrd,
importdude
So
the car is a 2005 acura type S
Setup planed is
Panasonic cd player
4 cHan sony amp> for all 4 speakers
monoblock apline amp for single 12
8guage knuconcept wiring
Distroblock
Front/rear preout used for sony amp
Sw out preout used to apline amp
8 guage ground/8 guage power
The problem is
The amps wont get power!
i measure 12volts on the live wire and ground.
When i measure the livewire/ground Hooked to the amp threw the screws
it gets 6-7 Volts only!
I dont know whats going on
PS
EArlier in the day i got bOTh Amps to Power up and i though i fixed the problem
So i uninstalled the amps to clean the wires up and mount amp to box first...
then it stop working again:(O
TIA
sorry for the grammer
You only have 8 awg going to the dist block?
If so, that needs to at least be 4 awg and 8 awg to amps, that may be a problem there.
Check the remote wires, how are they wired? If they are fine, try taking a peice of wire and put one end in the +12v terminal and the other in the remote terminal, if that doesnt work, check grounds, and all connections.
i tested the remote wire when the deck is on i get 12 volts
i tryed various grounds
sanded the paint, tryed the rear shock mounts
will a bad fuse be cuasing this?
When the amp is pluged in directly to the POWER/ground from battery and remote from deck it powers up fine:(
to be SURE
when connections to the amp are made
IT SHOULD read 12volts? even when the deck isnt on right?
importdude
importdude
san jose,ca
importdude
michigan born
    May 14, 2026
michigan born
    May 14, 2026
