Amp wiring
What you need is a fused distribution block. See this link: http://www.darvex.com/miva/merchant.mvc?Screen=CTGY&Category_Code=FDB
Here's what you would do:
- Run 4 gauge wire from battery to the fused distribution block (you would to mount it near the 2 amps you plan on using)
- From the distribution block you could then run 8 gauge to the to each amp
Also, you could use larger gauge wire if needed. For example, you could run 1/0 gauge to the distribution block and then from there run 4 gauge to the amps.
Tiiimay
Tiiimay
burlington, CT
Tiiimay
