amp wiring
No, not unless you want your sub to run in highpass or your 6x9's to run in lowpass, actually there is a way to do it with active or passive crossovers i think but i am not sure of how to do it. It would be easier to go and get a 4 channel amp to run your highs off the front and the bubs off of the rear channel.
if your 6x9's are running in low pass then they won't be making any noise, just pounding like a sub. Just run them off of your deck till you get another amp or a 4 channel.
358
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
927
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
SKMexiFry
...For a Porkchop, uh...
SKMexiFry
Port Orchard, WA
n2audio
    May 16, 2024
    May 16, 2024
