mikey
I have this:
Pioneer DEH-P7300 (extra info removed from description)
Infinity Kappa Perfect6.1
and I will be adding rear speakers later on, but for now leaving the stock ones in.
I want to know what specifications are appropriate for this car audio,
e.g.:
1) when im looking for an appropriate amp, what ohm level should i be reading it at?
2) how many channels do i need as a minimum?
3) what wattage should i have per channel as a minimum? if i have to worry about blowing my stock rear speakers i will unhook them
Thanks a lot, and if you have any time you can contact me in the following ways:
AIM: hitmikey
ICQ: 20034165
EMAIL: hitmikey@aol.com
with,MOSFET 50x4 - 4-Channel High Power Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
HPF Crossover
Sub-Out Level (-12dB to +12dB) and Phase Control
Hi-Volt RCA Preouts (x3 pair) (Front/Rear + Subwoofer or Non-Fading) (4V)
Power Handling, RMS: 100 Watts Power Handling, Peak: 400 Watts
Frequency Response (±3dB): 75Hz - 23kHz
Sensitivity: 90dB
Impedance: 4 Ohms
Crossover Frequency(ies): 3.5kHz, 24dB/oct
e.g.:
AIM: hitmikey
ICQ: 20034165
