Amp wiring right?
Haden
Dr Gibbles
Hey guys, I bought a truck recently and noticed it still had amp wiring from the last owner. I have a MTX 1500w amp (i think 750 rms) that i want to hook up. The power cable already in the truck is 8ga. Will the amp be fine on this power cable? Ive tried lookin this up but it seems everywhere says different power ratings for different cables. It would be much more convenient to just use the cable thats in the truck but i also want to get all i can from the amp.
yes. 8ga is usually only recommended for up to 1000watts I believe. you have 750rms which is fine, but to achieve your 1500 peak the wiring will help to get the MOST out of your amp IMO
4ga @ the minimum for your application. 8ga should really only be used for running 400w or less.
thanks there. Was trying to help out the best I could. I thought it was 1000watts.
Hope you get everything ran right!
Haden
Dr Gibbles
Haden
Here
JT1979
