amp wiring kit
You should... unless your amp runs on magic.
The remote wire is a 12+v current that is turned on when the car is on 'ignition' or 'run'. AKA when your radio's on.
It tells the amp to turn on. If you have an amp now... you should have the remote wire. It should be coming from somewhere in your dash.
no i know what a remote wire is
this black wire came with my kit
and it says remote GROUND wire its black
i looked on some other forums
and said that you dont need to use
only when your having problems with sound or something
moptopklee
moptopklee
Union, Ky
moptopklee
