Amp wire or big 3
I just listen to music, not a test tone. Set your head unit volume at about 3/4 or your normal listening volume. Have your gain all the way down, then turn it up until it stops getting louder, and/or sounds bad/different. Then back off a little. Not all songs will sound as loud as each others, because of recording levels. That's when you have to be smart and adjust the volume knob accordingly.
I'm not saying the DMM or O-scope methods are wrong, but they aren't fail-proof. I'd rather not rely on that, because music is different. You could set gains with an O-scope using a 0db test tone, and be fine most of the time. However, you would still need to turn your head unit volume up more to get the most out of some songs. Then, your head unit may distort the signal.
There's no perfect way to set your gains for all recording levels, and still get the most out of them.
Just my 2 cents on the matter. Others may disagree and swear by a method. All I can say is I've never blown a sub or amp.
Check out xplicit audio. I've been buying wire and stuff from them for a year or two. Good pricing and fast shipping. They are a supporting vendor on here.
The Sundown amps and subs have worked great.
[quote name='Bomber Z']Check out xplicit audio. I've been buying wire and stuff from them for a year or two. Good pricing and fast shipping. They are a supporting vendor on here.
The Sundown amps and subs have worked great.[/QUOTE]
I disagree. I refuse to buy from Xplicit anymore. They have the worst customer service I have ever dealt with. Rarely did they respond. Don't bother PMing them on here
Could be just me, but regardless, they will not get my business in the future.
@g6ryder; owns wooferwarehouse.com and has excellent customer service. He sells pretty much the same stuff. He does respond to PM's on here
ShadowElky
United States
adulbrich
