Amp will turn on...but no sound.
What are you using for a ground connection?
That same thing happened to me when I first put my sub in. The amp powered on, but no sound. The reason was because I had decided to attach the ground connection to the top of one of my rear strut towers, which was a terrible connection to the body of the car so it barely let any power trickle though. Get a multi meter and make sure your ground connection is electrically connected to the rest of the car.
as said above, checking ground is always a good start when troubleshooting. i'd also try another source such as your phone via a 3.5mm to male rca adapter. if you get sound with that then you have narrowed it down to either your RCAs or your headunit. if you get no sound you have narrowed it down to your amplifier or speakers.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
807
YES.The Remote wire turns the amplifier On/and OFF. If you use a Toggle switch as stated, use one that Lights up so you know if its still ON or...
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
  • Locked
229
Amp
266
GSRswapandslow
GSRswapandslow
Taylorsville, NC
Louisiana_CRX
    May 12, 2024
Brendon Jenness
    May 11, 2024
