amp to amp wiring
does the amp turn on at all? if so check the subs make sure your wire did not come loose. Also check remote wire if the amp isnt turning on, o yeah and it coulb be bad ground, bad amp...you have plenty more to check before ruling out the radio
amp turns on checked with a dmm everythings getting power (and subs will work if i switch the rcas out of the component amp into the sub amp) and everything was just rewired grounds are good i know for sure, i had it professionally rewired last night and the distro block put in remote wire is getting power and plugged in, amp is new and like i said works when you put the other rcas in
Finally got it working, did some more wiring stuff and the ground came out when i moved the box back
thanks for all the help
frumpy
frumpy
ontario
frumpy
