Amp/Sub Assitance
Gr3mlyn
Ok, so I just picked up a set of 2 12" Kicker comp c12's 8ohm with a Baja 1000watt 2 channel amp . The amp is bridgeable and I currently have it bridged. My question is the c12's have a rms of 150 watts and peak of 300 watts apiece. Is my current setup going to burn the c12's in this configuration?
Specs on the Amp
# Peak Output Power (4 ohm): 350W x 2
# RMS Output Power (4 ohm): 160W x 2
# Peak Output Power (2 ohm): 500W x 2
# RMS Output Power (2 ohm): 240W x 2
# Bridged RMS Output Power (4 ohm): 480W x 1
# MOSFET Power Supply (Dual)
# Total Harmonic Distortion:
# Signal / Noise Ratio: 100dB
# High Level Inputs
# Pre-Amp (RCA) Outputs
# Variable Bass Boost at 45Hz: 0-12dB (Variable)
# 12dB Octave Crossover (High Pass/Full/Low Pass): Full/LP
# Variable LP Crossover Frequency: 50 – 250Hz
# Variable 12dB/Octave Subsonic Filter: 20-50Hz
# Fuses: 2 x 30A
# Dimensions: 14 3/16” x 2.25” x 9 11/16”
# Profile 1-Year Warranty
# Warranty: 1 Year Rickie's Discount Electronics Warranty
Gr3mlyn
Gr3mlyn
Boise
Gr3mlyn
