There probably not going to warranty it being him at fault.see if you can get it replaced through warranty
yea probably right, cause the owner is a *******.There probably not going to warranty it being him at fault.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifDude every time you log on you better put on your flame suit, this forum just talked trash in every post, get use to it.....Cig smoking and Smoke from ur bbq is bad....Ur hurting the O-zone
That is almost sig worthy there man //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifsilvercookie, this is offtopic and doesn't relate to this situation , but is it possible to wire 2 dual 4's into 2 ohms??? Such as... you have a mono amp with 2 channels, you wire 1 sub into 2 ohm, and use channel 1, and wire 2nd sub into 2 ohm also and use channel 2, wouldnt that be a 2 ohm load on the amp???
It is possible they are SVC4's but I'm not fimiliar with Kickers coil optionsfirst of all you cant wire 2 dual 4ohm subs to 2 ohm
so that means you ran the amp at 1 ohm bridged, which it is not supposed to be ran at.
it was your fault the amp blew up.
Thats still a 1ohm load. That is used for wiring options at the amp. Still presents a 1 ohm load at the amp. And a Mono 2ch huh?? Hook me up.silvercookie, this is offtopic and doesn't relate to this situation , but is it possible to wire 2 dual 4's into 2 ohms??? Such as... you have a mono amp with 2 channels, you wire 1 sub into 2 ohm, and use channel 1, and wire 2nd sub into 2 ohm also and use channel 2, wouldnt that be a 2 ohm load on the amp???
He was offering to buy a blown amp from you. Instead of being an assclown and flipping shit you could have made some money towards a new amp. Throw it in the trash if its so annoying.how about you try not being such an *******, i can see you know your shit, but all the throw it out and if you dont want it ill take it is annoying.
