Amp Setup Question
darkdrake
Darkness is me
ok heres a link to the amp i currently own:
http://www.sonicelectronix.com/item_3533.html
i have 2 12 inch kicker l5's going to it dual 4 and together they are wired to a 1 ohm load.
this amp puts out 1200 watts to 1 ohm load.
now here my question on my amp i have this right now from the amp
i have both positive wires from the box running in the one positive terminal on the amp, same for the negative, both are wunning to the same terminal..
so do i have them wired correctly or should one subs wires run to one set of terminals and the other subs the the other terminals?
sorry if this is confusing...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
diagram came out wrong i have both positive wires from the subs running to one positive terminal, and both negatives running to a negative terminal...
darkdrake
Darkness is me
darkdrake
Fleburg,Ky
darkdrake
