Amp recommendations?
Chev13696
I have a pair of kicker comp R 12" subs 1600watts peak and 800 watt RMS per sub. Just curious to see what kind of amp some of you might recommend. Was looking at a mono block amp but not sure what brand or wattage to go with. Oh and it will be going into a 2003 Chevy Tahoe.
Here are the quick stats on the subs
ported enclosure with two 12" CompR subwoofers
medium-density fiberboard construction covered with carpet
2-ohm total impedance
power handling: 200-1,600 watts RMS (3,200 watts peak power)
frequency response: 25-500 Hz
sensitivity: 98 dB
31-7/8"W x 16"H x 16-7/16"D1 x 13-7/16"D2
To be honest I am not sure I think that they have a ohm switch on each of the subs to change them from 1 ohm or 4 ohms so I think when wired together the make the 2 ohms.
This is what I pulled from best buys website about the 2ohm Impedance.
2 ohms impedance
Conducts power evenly to keep the speaker at an appropriate level. Impedance-selector slider allows you to change the 2-ohm DVC impedance to 1 or 4 ohms for flexibility.
1600watts peak does now mean rms... i'll say don't send any more than 400wrms to each woofer.... even then they still have too much pwr
what is the rms of the sub?
whats the max of the sub?
whats the peak of the sub?
If you read my post I already stated the RMS per sub which is 800 watts RMS so together they have 1600watts RMS. The peak per sub is 1600 watts for a total of 3600 watts peak.
Chev13696
Chev13696
Minnesota
Chev13696
