Amp randomly decreasing in power
im.the.new.hero
I hooked up a hifonics 1500d to my alpines yesterday and it all seemed fine until it randomly stopped working so I turned it all the way down on the bass knob and after playing with it a little it started to work it's doing that a lot now and I'm not sure what to do about it. Any ideas/suggestions? Thanks in advance.
they're 2 alpine type r's wired down to one ohm and its a stock electrical system. Not sure what my gains and boost is set too im in school atm. i dont think the knob/wire is broke it works fine when the amp is actually putting out power.
your running a 1500d (not sure what rms or what kind of amps that pulls) on a factory electrical, that could well be your problem there. if your voltage is dropping way low then its going to get quiet, run you car for a bit with the system off to make sure the batt is well charged, then turn everything on and to full tilt and check your voltage with a dmm, if your voltage is dropping way down then you have most likely found your problem.
im.the.new.hero
im.the.new.hero
Eye of wa
Sweet'n Low
vegang
vegang
