Amp Question
Will the AQ compare to the power of the sae 1200d i had?
It would be within a couple hundred watts, & you'd never be able to hear the difference in a couple hundred watts.
dont listen to this guy
dude why in the fhuck are u worried about what the fhuck I say and do on here u are no one to me I don't care how many posts u have get off my fukin nuts bit.ch. I'm not with that gay sh.it but u seem to like to follow me around he wants to no what will put out the same as as sae 1200 and a opti 2000d will and its in his dam price range. Lame as bitc.hes on this site
LMFAO umadbro??? you give some of the worst advice on this site. thats why i constantly say "dont listen to YOU". you obviously are a little **** if thats the first thing that came to your mind.
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
761
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
chrisf3421
chrisf3421
Georgia
sacsking916
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
