Amp power
The_Councillor
I have a Kenwood KAC-8105D, on the box it says max power 1000 watts. The place I bought all my stuff from said that this soundquest SQ600xb 8 gauge wire kit would be able to hook it all up. Now that I've done a bit of reading I found out this kit is for amps up to 600 watts.
Is it going to be fine to use this kit and the fuse holder with the amp? The two subs I'm running both say 300w rms power, not sure if that really has anything to do with it or not.
I might get away with 8? So in other words I might also set my car on fire???
I mean the amp says 1000 watts, and the wiring kit is for 600 amps...
Is the amp really going to be putting out 1000 watts?
Or well, looking at the manual for the amp it says..
Max Power Output 1000w
Rated Power Output (+B=14.4v)
(4ohms) (20 Hz-200Hz,
(2ohms) (100Hz,
The subs I'm wiring both have an impedance of 4 ohms and need 300 watts, so will the amp only be putting out 600 watts of power?
(2ohms) (100Hz,
Regardless of what your subs need, your amplifier will not produce more than 500w.
So will it even power my subs and will the 8 gauge and fuse work for it?
Sorry for all the questions, new to this stuff and just won't want anything to blow up or catch on fire.
The_Councillor
The_Councillor
Texas
LosIsATool
