Amp not working need help fast!
  • 4
QuadPioneer
Spinnin' Tracks on Flat
600
Canada
Aight i got a little JBL 80.2 or something. Anyways for some strange reason its being gay and wont work? It iwll turn on, i get a green light, but it wont power my sub? And then sometimes when im driving and i hit a bump it will come on for a bit then die out.. Almost like somethings loose? But i checked all the connections and its all seems fine?
Do you have another amp to mount in place of the Jbl amp.
This would be a way to determine if it is the amp or something else.
If you hook up another amp and it still doesn't work you know
the problem probably isn't the amp.
If you hook up another amp and it works then you know it's the JBL amp.
Could be the pre-out from the radio. (Internal Deck Problem)
If you have multiple pre-outs available try switching to a different
pre-out on the radio.
Just a few thoughts
Good Luck
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
QuadPioneer
QuadPioneer
Canada
AScreenName
    May 12, 2024
Brendon Jenness
    May 11, 2024
