Amp not turning on
orioles26
I had to change the wiring on my subs and add speakers. Now that i did this the amp will power up sometimes but most of the time it wont even turn on. It will usually flicker on when i start the car but sometimes it will never come on or it will play for a little while while im driving then cut out again. What could be the problem because all of the wires seem to be connected and the fuse is not blown?
Two rockford fosgate p3 dual 4 ohms wired to 1 ohm on a hifonics 100d amp. The wiring to the head unit is fine because i did not change that when i redid the wiring of the subs. The only thing i changed was the wiring on the subs.
Maybe the remote wire got pinched. My friend had that happen a few times. Run a wire from the battery to the amps turn on and see if it turns on, if it does I would just put a new wire in for the turn on and see if that work. Just a thought //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no he is saying run a wire from the battery's positive terminal to your amps remote input instead of the one coming from your cd player to see if that is the problem
orioles26
orioles26
Severna park, Maryland
denim
