Amp not getting power
blitz_fist
I got my amp today, and hooked it up but it wouldn't turn on. I got the multimeter and there's no power at the end of the wire.
Could it be a bad ground? I'm going to try a new spot now,
Or did I hook it up to the battery wrong? I don't have a new battery terminal, I just unscrewed the stock one and kind of ran the screw through the wire's connector.
Ok, so I relocated the ground and I'm getting 12v at the connections, but it still won't power on. I'm also getting alternator whine when I turn the car on, but the amp won't turn on. Maybe the amp is bad? I just bought it off eBay.
no you need the Remote wire ran to the amp to turn it on. it wont turn on with out it.
Absolutely correct.
The power and ground connections are simply that.
They provide 12v positive power and ground to earth connections.
Without the remote activation lead attached the amp will not receive the necessary input signal telling it when to turn on and off.
Hmm, I tried using the blue with white stripe, but I'm getting the same results. With the wiring harness it should be three wires spliced together right? (including the remote turn on lead)
blitz_fist
blitz_fist
Sarasota, FL
blitz_fist
