Amp issue pdx 4.150
Mk4
7
Pa
Hey guy's
I was installing my Alpine PDX 4.150 to run my 4 door speakers. I accidentally dropped the power wire onto my positive battery terminal causing a spark. I checked the amp and I blew the two 30 amp fuses. I put two new fuses into my amp and hooked everything up correctly with no idiot mistakes. Only this time my amp wouldn't turn on. I checked all fuses, connections and even changed the amp remote wire. Amp still wouldn't turn on. I switched my alpine amp with a JL amp and it worked perfect. Does anyone know what I screwed up. I'm about to send it into alpine for repair. Any ideas of what I can do to fix it or where to look for damage? Anyone have an issue like this. Any help would be great.
Thanks
MK4 (Amp Killer)
Make sure new fuses are seated properly. Try connecting and just jumping the remote straight from the power to turn on. Double check connections. I don't think just dropping the the power wire onto the pos terminal would kill the amp. Are you positive the amp worked before installation
I made sure the fuses were seated properly and all connections were properly connected.
Still no power
I will run a hot wire to the remote connection ill let you know the result.
As to what happened: when I dropped the cable a spark was noticeable and I agree that I shouldn't have blown the amp. What's strange is that the inline fuse wasn't blown. Also when I switched Amps the new amp worked and the Alpine didn't. I did have the alpine amp working previous but decided to reinstall that's when the spark occurred.
Mk4
Mk4
Pa
SUNDOWNBITCH
