Amp Install killed Starter
Do you mean the starter motor is burned or your car wont start.
check fuses.
If your starter motor is bad its just a coincidence, there is no possible way that an amp install can burn a starter motor.
Check the basics. I installed a head unit in my truck, get done & the truck won't start. I pulled the head unit out twice double checking if I knocked something loose in the dash etc..
Turned out my battery gave it up. what a coincidence.
jonny101abc
SOCAL Stang-Man
jonny101abc
San Diego Punks!
kraco
michigan born
    May 14, 2026
michigan born
    May 14, 2026
