amp help
limppimpin
i was wondering if im going to need a new alternator or capacitor for my system
2003 pontiac grand am (105amp alternator)
2 v109d6 visonik 10" subs (600wrms)
alpine mrd-m1005 (1000w Rms amp
alpine cda-9833 head unit
i would realy apreciate the help
thanks
Get a 250+ amp alternator + a 5-farad cap to be on the safe side, I would...
Don't listen to this guy, he knows nothing on the topic of car audio.
Don't worry about a cap, those things are useless for bolstering a charging system.
I would hook everything you have up and see how bad or if at all the dimming is. IF its an issue, then replace the Big 3 wires (alt + to batt +, Batt - to chassis, chassis to engine). If its still there, look into a better battery, like an optima (or any other deep cycle or gell battery). IF those don't fix it, then look into a HO alternator. Most likely, a 160-180A would be just fine for you.
Iraggi Alternators, produce 75% of the amperage in the lower ranges of RPM, so you get more juice at idle speeds too. Plus he is cheaper than Ohio Generator, Mean Green, Stinger, etc...
limppimpin
limppimpin
canada
AzGrower
