Amp help!!!!
adams00civic
I just ordered these today to replace my ancient sony xplods that i have had for years that finnaly gave way last week.
well i got 2 KICKER CVR10"'s
here is the specs:
•800 Watt MAX
•400 Watt RMS
•Dual 4 Ohm Voice Coils
•Progressive-Roll
•Polycotton Spider for Imporved Linearity at High Volumes
•Spiralead Tinsel Lead Technology
•Polyimide High Temp Former
•Dual High Temp Voice Coil Wire
•Ribbed Santoprene Surround wit Improved Performance at High Excursion
•Injection Molded Polypropylene Cone with Aluminized Coating
•Constant Contact Back Bracing on Cone Eliminates Distortion
•Stamped Steel Basket With Perimeter Venting
•2 Year VMinnovation Warranty
What Watt amp would work best for these subs? i would like to get another 2 channel amp the one i had on my xplods was a 430wat sony amp? would that be enough to power it for a while until i can find another amp?
thanks so much in advance.
the cvr's sensitivity rating is 83.6 db, thus not very efficient so even though the sony amp will produce some sound, don't expect much as you'll need to wire the subs in series unless the sony is 1 ohm stable. i'd look for a mono amp rather than 2 channel, in the 750~1000 rms range. set your gains properly. let us know your price range for the amp and we can make some recommendations for you.
Well, if that amp is 2ohm stable in stereo, then it would be fine pushing them..... Even though they are only rated at that sensitivity, they still play well at higher volumes..... An 800@1, or 2x400@2ohms will work good, and you could always go with a zx750, which would be perfect, or look around the classifieds here for anything that sparks your interest... Just remember not to push the amp past it's limits. The modern kickers are a little more sensitive to clipping heat...
adams00civic
adams00civic
Yadkinville,NC
adams00civic
