amp help
beatthis27
ok im new to these forums but i used to be heavy in systems, changed setups every month in my cars, but i been out of the "scene" for 2 years and its like i forgot everything... i got 2 setups i traded around for and just wanted to know the best way to set them
first the one actually in my car at this point
i got 2 memphis audio PR 10's in a slot(middle) ported box with a P3001 rockford amp on the amp what should the hz be set at and where should the gain be at how should i set all this thanks
now the second
i have a older tri MTX blue thunder 10's box, ive had prolly 4 of these in my lifetime and love them, the amp i have for these that my friend had on them is a older rockford punch 201s 600 watt amp, now it only has a gain knob and a rocker switch that has 3 spots one says 0db one says +6db and the other says +12db which position should the rocker be at and where should gain be at for this setup thanks so much for any help //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
ive read tutorial and realy just dont understand it was hoping by the setup and specs someone could tell me where to set em thanks
http://www.caraudio.com/forum/attachment.php?attachmentid=6797&d=1164786041
first q, set the LP filter around 80hz.
there are a few tutorials on gain setting, i usually just do 1/4 - 1/2.
second q, i dont know much about that amp, im guessing its a db boost setting at a certain freq thats not ajustable. check the amp it might say 45hz with
0/+6/+12db boost. if it doesent have what freq on the amp, search rf database im shur you can find the pdf file on there website.
beatthis27
beatthis27
chattanooga, tn
beatthis27
