amp help!!
gansan
sup guys....i just tried installing my new system by myself but the amp wont turn on! it had power for a bit after connecting all the wires for the first time but it has no power at all now. how can i check if my new amp is blown or defective?? i believe i connected all the wires correctly..... plz help!
umm check ALL your fuses, REM wire
btw i tightened all my connections //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
LOL....cool. im thinking maybe my wires r cheap as hell.just hoping that my amp isnt blown.
wat size is the remote wire? the one i got with the amp kit looks real shitty.
the REM is only supposed to be 18 gauge at biggest. Nah i doubt your wires are crappy.
try tightening your connections and make sure they are GOOD connections
the irony lol.
i just went to go check the wirings again n everything seems to be connected ok. the grounding point was the same one as my old system n i checkd the fuse under the hood n on the amp n both fuses were fine. **** it.....i really dont wanna go n pay to make it work.
does the HU turn on? or is it just the amps?
replace the fuse under the hood, one time I did have the same problem and the fuse was blown but so little broken I didnt see it. Once I took it out still looked good changed them and it worked. I dont think this happens much but whats a $2-4 fuse compared to the $60 a hr there gona charge you to look at this. Also check your remote turn on wire on the back of your hu. Make sure that did not come off as well. OR just get a tester and make sure each wire has power but the ground at your amp. And that will tell you that your fuse and remote wire are fine.
it says that its suppose to be 450 watt @ 2ohm and i bought the 4 gauge amp kit but its really cheap n thin. its lot thinner then my old wires...
i just went n got a new fuse n the power lights up now!!(thx for that advice voa) =) but im still getting no sound from the sub..... any ideas?
gansan
gansan
LA,CA
VOA_NIGHTMARE
