Amp Help....(wiring)
Jax8287
Ok here is the problem, I currently purchased two JL Audio 12" W3's at 2 Ohms each. I am eventually planning on buying the JL 500.1 once i can gather up the money. Well anyways before that I was told to buy this amp that is 400 watt amp at 2 channels or 1. This is a pretty good amp actually it has 400 watts rms so i figured that i can use it temp. for the 2 JL's. The only thing was is that i do not know how to convert this amp into a single channel amp. I lost the instructions and i cannot seem to find any information about this amp online. It is a (Total Moblie Audio Amp by the way) I was told that if i wire the two subs parallel into a mono amp i can get them at 4Ohms. So i guess my question would be is how can i convert this amp to a 400 watt x 1 bridged into 4 ohms.It says that it is cablable so i am just asking for any help that i can get. Thanks
Kyle
1. this a 2 channel amp?
2. you are trying to get 1 channel?
what you are trying to do is "bridge" stereo to mono:
when you hook up the subs, sub- goes to channel1-, sub+ goes to channel2+
hey thanx i appreciate that alot! now that u mentioned it... i think i recall someone saying that a while back, but yes that is what im trying to do and thank you for your time and response
Kyle
Jax8287
Jax8287
Tampa
Jax8287
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
