This is the inside of my JBL px300.4. I have narrowed down the noise in my system (HISS) to the amplifier itself by
1) Using muting plugs
2) Removeing the amp from the vehicle and using a "test bench" if you will and a test speaker to find the same noise.
It's a low hiss with the vehicle OFF and ear right up close to speakers.
By "test bench" I mean I connected the amp right by my battery with the ground going straight to the battery and used a test speaker and adjusted every setting on the amp with no change - gains at zero - no rca's connected.
So I took off the cover not the entire sink case and looked around. Here are the two things odd I found. I'm no expert and if this won't cause noise, I'll just have to live with some minor hiss till I get it repaired or get a new amp.
