amp going into protect?
ill have a look at it. maybe i need to get some paint off it. hope its as simple as a new ground. i found an amp i can borrow and hook up to see if its just my amp.
i finaly got home early enough to use a dmm and test the voltage drop. i think i found the problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i didnt have it up to where the amp cuts out but had it close and it went down to 11.5. maybe a little more. i think that ground wire under the hood was the problem. i made a new, much better, ground. couldnt test it cause its to late. should have time tomorrow to test it out.
if i need another battery could i just use my stock one and put it in the trunk? at least for now? or for good?
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif:awesome://content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif:eek:mg://content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif:drool:
//content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif//content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif
fixed it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ARE YOU RETARDED?!
Yeah, put an acid-filled plastic container in your trunk. That won't do anything bad.
ARE YOU RETARDED?!
yes i am.
this was actualy a lot of fun to fix. i just got back from my grandpa's funeral and cleaning out his old metal shop. i got to use some of his old tools to make a new ground spot. i still got it to go into protect but this time both my amps did it lol. so i think its time for another battery... it felt like my car was going to explode.
yes i am.
Yeah...
You should stop doing that.
Over time low voltage will kill your amp.
skittlesRgood
skittlesRgood
fremont, ca
skittlesRgood
vegang
vegang
