amp goes into protect mode after turned up
May not be an issue today but years ago I had the + and - crossed to a speaker on one channel and hooked up right on the other channel. Would do fine on low volume, turn up and it would cut out. Wasn't any protect mode back then.
One possible thing that may not have been thought of is the resistance level. If you have the resistance wired at a lower resistance than that capable of the amplifier, it will want to push more current than possible, and could short the circuit, or trip the protection, and even blow a fuse if done suddenly at a very low resistance level. Check that your amplifier is capable of the resistance that you have the driver(s) wired at. May be a possible solution as well.
meaning if the amp is stable at 1 or 2 ohms and wire it down to 0.5 ohms your stressing it out
Exactly. But mainly when the ampere levels are exceeded, not necessarily just with voltage and resistance, but still very important not to exceed as well. Just not a good idea in any case to use a lower resistance wiring than the amp is stable at.
impedance they mean (ac) resistance is dc
Impedance can be thought of as DC if it is biased/fluctuating, but yes...generally AC is frequency dependent and is related to impedance. Good point. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
s.l.a.b
s.l.a.b
austin,tx
globalminds_ent
